Eos Family Level 1: Essentials (v2.9)
Availability: In stock
$0.00
Quick Overview
All the basics to start working with your lighting desk!
Course Completion: 6-8 Hours.
Double click on above image to view full picture
Zoom Out
Zoom In
More Views
Details
Are you new to the Eos family of consoles and want to hit the ground running? Learn all the basics you will need to get started in our Essentials class. This class will give you a solid foundation with the Eos family of consoles and prepare you to grow your knowledge as you are ready. After completing the level, you’ll be able to:
  • Patch conventional and multi-parameter fixtures
  • Work with channels in Live mode
  • Record, select, and delete Groups
  • Record to, load, and clear Submasters
  • Record, play, and delete Cues
  • Understand Tracking and Block, cue timing, and Park
  • Manage show files (create new, save, save as)
  • Control non-intensity parameters at a basic level
  • Create simple step-based Effects
